Hypothetically speaking, if a ******* were under the hood of his truck and happened to snap off the nipple that connects to the radiator overflow tank from the RADIATOR, is that a complete radiator replacement?
I hate to say it, but yes I think so. Unless you can tap it with a pipe tap, and thread in a nipple fitting. Might Not the easiest task into a plastic tanK
I just replaced mine, $460 for radiator 2 hours labor at Ford dealer, you may do better elsewhere.
The dorman kit is the best thing to do. Plastic jb weld epoxy is crap and cannot stand up to the constant expanding and contracting that a radiator gets. I've been in the cooling business for over 17 years. The epoxy is a temp fix at best.
Here is a link to an earlier thread, same subject.
