code 122 low voltage tps?
I tested the tps sensor.
Ground to signal return = .7 ohms
koeo ground to reference volts = 5.05 volts
koeo ground to tp signal I get less then a volt but when I move the throttle it doesn't change so I replaced the tps twice and get the same reading from both new sensors. Both were bought from advanced auto bwd brand. Whats the like of two sensors being bad? Or am I missing something?
Truck is a 1994 4.9 e4od 310,000 miles
What do you see between signal return and TP signal?
SIG_RTN and GND should be the same level. Should be. As you see, though, on your truck they aren't.
Are you testing the sensors before you take them from the store? They should show a smoothly increasing resistance between the SIG_RTN and TP_SIG pins as you turn the element inside. If it doesn't, it's defective.
You may want to read what is in this link below if you have not read it yet.
Fuel Injection Technical Library » Throttle Position Sensor (TPS)
Good information, Bill.
Four ohms as a reading for the new TPS jumped right out at me, Spyder, because with a five volt reference voltage applied to it it will dissipate more than six watts. The life span of what is, at best, a one-watt resistive element would be measured in seconds or minutes if it dissipates that much power. If it actually is reading 4000 ohms, lifespan would be measured in at least years. Since that is only a difference in range, not in the base reading, it would be an easy thing to overlook. (I cut my teeth on a Simpson 260, with multiple possible ranges for each needle position. I still mistake the range on occasion, especially if I am tired or harried.)
<a href="http://s1320.photobucket.com/user/seanspyder0382/media/20131203_170926_zps9d344297.jpg.html" target="_blank"><img src="http://i1320.photobucket.com/albums/u534/seanspyder0382/20131203_170926_zps9d344297.jpg" border="0" alt=" photo 20131203_170926_zps9d344297.jpg"/></a>
<a href="http://s1320.photobucket.com/user/seanspyder0382/media/20131203_170902_zpsc6b1d0e6.jpg.html" target="_blank"><img src="http://i1320.photobucket.com/albums/u534/seanspyder0382/20131203_170902_zpsc6b1d0e6.jpg" border="0" alt=" photo 20131203_170902_zpsc6b1d0e6.jpg"/></a>
<a href="http://s1320.photobucket.com/user/seanspyder0382/media/20131203_170918_zps1427b085.jpg.html" target="_blank"><img src="http://i1320.photobucket.com/albums/u534/seanspyder0382/20131203_170918_zps1427b085.jpg" border="0" alt=" photo 20131203_170918_zps1427b085.jpg"/></a>
<a href="http://s1320.photobucket.com/user/seanspyder0382/media/20131203_170147_zpsff616bea.jpg.html" target="_blank"><img src="http://i1320.photobucket.com/albums/u534/seanspyder0382/20131203_170147_zpsff616bea.jpg" border="0" alt=" photo 20131203_170147_zpsff616bea.jpg"/></a>
oceanblues
10-16-2018 10:58 AM
slicker_22
1983 - 2012 Ranger & B-Series
09-19-2006 12:41 PM
jwtaylor
22
11-25-2003 08:49 AM
