And the bad news continues
Old 06-20-2014, 08:03 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
I have the starter from the 226 cid that was in Blue. I don't know the condition or if it is the same. If you want, I'll verify it works and meet you in Spring City for breakfast.
I am with Ross, probably a ground problem. Have you jumpered the relay? Get any sparks, any noise?
  #62
Old 06-20-2014, 08:13 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
I am sure it will fit, I believe they were all the same then. where in Spring City...time?
  #63
Old 06-20-2014, 08:23 PM
raytasch's Avatar
raytasch
Believe Nothing
Scrambles restaurant. It is west of the tracks about the middle of town, across from, and north of the Ace hardware. How about 09:00? Marcia and I will be in blue. You have my phone #. I'll go out and pull and check the starter. Go PM if we need to continue the discussion.
  #64
Old 06-20-2014, 08:27 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is online now
Received 2,113 Likes on 820 Posts
Starters can be different. I had a bad starter end plate in my '49 F-2 with the flat 6. I also have another parts truck in the back of the farm, I know it's a '48-50, but not sure, with a flat six. No problem, I'll pull the starter out of the parts truck and use the end plate. I pulled the starter and set both on the bench and the starters were different, one had a shorter case than the other by about a 1/4". Overall length was the same but the end plate on one had a thicker edge that made up the difference. I couldn't just swap parts. I ended up rebuilding the starter out of the parts truck. It bolted right into my truck and working today. Maybe one of the starters were an aftermarket unit, I don't know. With Ford you never know, they might have gotten a better price from one manufacturer closer to one of their plants or changed in mid year.
  #65
Old 06-20-2014, 08:34 PM
harleymsn's Avatar
harleymsn
Sounds good.
  #66
Old 06-20-2014, 08:49 PM
raytasch's Avatar
raytasch
Believe Nothing
Sounds good.
Ok, Joe, I pulled and bench tested the starter on 12 volts and it works. Does your starter bench test? Have you tried it?
  #67
Old 06-20-2014, 09:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Any chance the starter came apart while putting it in, and a brush came off the armature?
  #68
Old 06-22-2014, 06:52 PM
harleymsn's Avatar
harleymsn
Well, I got Ray's starter in and she turns the engine fine, now to put it all back together again.
  #69
Old 06-22-2014, 06:58 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Good to hear Joe.
Hope it all goes well and you're back on the road soon.
  #70
Old 06-22-2014, 07:04 PM
harleymsn's Avatar
harleymsn
Originally Posted by Jolly Roger Joe
Good to hear Joe.
Yea, I hope so too. Once I get it running and back together, I guess I'll be making a stop at the starter shop.
  #71
Old 06-22-2014, 07:13 PM
Jolly Roger Joe
I understand completely, but it just sounds funny... stop at the starter shop. Sorry...
  #72
Old 06-23-2014, 05:55 PM
harleymsn's Avatar
harleymsn
OK, during my diagnoses I had removed the fan and shroud, with Ray's starter in and Edith running I finished reinstalling the fan and the shroud, put the front bumper back on and she is puuuuurrrrrrrrrrrrrring!!!!!!!!!
  #73
Old 06-23-2014, 06:04 PM
raytasch's Avatar
raytasch
Believe Nothing
Great. Thanks for the update. Now, put some miles on her.
  #74
Old 06-23-2014, 08:23 PM
Jolly Roger Joe
Outstanding!
  #75
Old 06-24-2014, 12:35 AM
tnguynaford's Avatar
tnguynaford
tnguynaford is offline
I am glad Edith has made a full recovery!
Quick Reply: And the bad news continues
