Thermostat water outlet for 352 v8?
Ford changed the size (from smaller to larger?) around '67. I recently replaced mine in my '66 which has a Streetmaster intake and stock housing; I think it took the small one. I used a Stant 195*, p/n 13479.
You could source one and measure it. The one I removed was bent and inoperative, perhaps because it was too large.
Eric
Eric
Why did you take the current one out? Was it leaking? Was it working?
John
Look at the photos on the bump form thread about 11 down. It shows one installed although backwards in backwards. Is NAPA the only parts store in Portland??
https://www.ford-trucks.com/forums/1...ease-help.html
John
John
I looked online at Advance at the Stant 180º for 66 352 and found 13078 for $5.00
Buy Stant Thermostat, 180 Degrees Fahrenheit 13078 at Advance Auto Parts
and 76 F150 360, I found 2, 45358 for $8.00
Buy Stant Superstat™ Super Premium Thermostat, 180 Degrees Fahrenheit 45358 at Advance Auto Parts
and 13008 for $4.00
Buy Stant Thermostat, 180 Degrees Fahrenheit 13008 at Advance Auto Parts
You may be making this too hard. I usually talk with the guys at the parts counter and if I have a problem they don't mind pulling boxes and comparing parts if I still have questions, but yall may do it differently over on the left coast.
John
and 13008 for $4.00
John
