Trans lines need some ideas
So I noticed on my new truck the trans lines are looped and not plugged on to rad cooler. Just 2 metal lines with a piece of rubber hose and clamps tying them together. I was gonna just reattach them when I noticed the darn fittings are slid back on the rusty lines and and have now rusted in place. I don't want to replace the lines. Could I just put new fittings on the cooler with short stubby lines approx 2 inches then use rad hose to join the stubs with the original lines. What do you think?
Agree there is some reason the originals are not connected. Fittings buggered up? leak? Also agree a cooler in front of the radiator is a good fix. Your transmission will thank you. Get a big one and no other cooler is required. Connection to the added cooler is typically by rubber line so you can just take off the rubber "jumper" and hiook it up.
Not really necessary but some penetrating oil and gentle heat + time may loosen up the rusted tube nuts.
Make this a lot simpler and just replace the lines. Transmission cooler lines are reproduced for a lot of common applications. Check with Inline Tube. If they don't have your original set already in stock, they can custom duplicate your original lines. I've used this service multiple times.
SoCalAngler
1999 to 2016 Super Duty
09-02-2017 09:33 PM
86bullnose95
03-03-2013 08:16 PM
