I think I broke an axel
Old 11-21-2013, 08:13 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
You will still have to set up your gears with a new carrier. Plus buy a bearing kit...that's probably another $100. It's a shame your on the west coast I could out you in touch with complete 9" for $200 or less. I would seem to think you could find another 9" out there and rob the center section with gears already set up.
Old 11-23-2013, 08:37 AM
rogue40's Avatar
rogue40
rogue40 is offline
^This is by far the quickest and most economical way to go.
Setting up gears for the first time is best done with a mentor.
Old 11-23-2013, 10:39 AM
tabascom16's Avatar
tabascom16
tabascom16 is offline
You broke the carrier in the exact same spot I did years ago on a 77 F150. Stock 350 engine and tiny donut tires with an open carrier...I tried to do a hole shot and "BAM". I am scared to beat up on a stock 9" now.
There are many 9" axles in junkyards. All I did was buy another complete 9" axle for $100 and just swapped it in. Way cheaper and quicker than starting from scratch.
Old 11-23-2013, 11:37 AM
myoldfords's Avatar
myoldfords
myoldfords is offline
Originally Posted by biggyfan1
My axel ended up being fine. Looks like this is what I might need. Does this look about right guys? I'm not trying to spend a lot of cash.
Summit Racing® Ford 9 in. Trac-Loc Differentials SUM-CTF9TRACL31 - Free Shipping on Orders Over $99 at Summit Racing
That will work, it looks like you'll also need a housing since the bearing cap is cracked. While your there, I would install new bearings and seals. I would also find someone who is experienced in rebuilding diffs to set it up so you know that it is right.
Old 11-24-2013, 07:26 PM
biggyfan1's Avatar
biggyfan1
biggyfan1 is offline
Ok so I now am going to buy a new center section case. Just the case nothing else.... I see 2 different types. Do we have the large bearing? The 2 different ones I see are 3.062 bore or 3.25 bore. I just want to buy the right one
Old 11-24-2013, 10:30 PM
rogue40's Avatar
rogue40
rogue40 is offline
Do we have the large bearing? The 2 different ones I see are easy. 3.062 bore or 3.25 bore. I just want to buy the right one
Probably. How you tell is by the nuts that hold the anchor plate and brake plate in. If the wrench size for these is 3/4" then you have the big bearing.
3/8" means you have the small bearing.
This will not have any effect on what case to get. All that matters is that the axle spline count and the carrier spline count is the same.
Old 11-24-2013, 11:00 PM
biggyfan1's Avatar
biggyfan1
maybe you guys can take a look at this case for me. Is this a standard case? I already bought the carrier and bearing set I just want to make sure everything goes together. Thanks.
http://broncograveyard.com/bronco/i-...-062-bore.html
Old 11-24-2013, 11:44 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
Just upgrade to a d70,sterling or 14 bolt with a posi.
Edit:I seen you bought parts. That's a shame. I'd of gone a different route.
Old 11-25-2013, 12:00 AM
biggyfan1's Avatar
biggyfan1
I want the stock case. Don't want anything other then what I need.
Old 11-25-2013, 12:10 AM
73 ford guy
Just think your throwing too much $ into a 9". Another 1 ton diff could be found for $200 or less. I look at times like this to upgrade.
Old 11-25-2013, 12:13 AM
biggyfan1's Avatar
biggyfan1
Don't have the time, patience and the weather is not permitting. So again I just want a New case.
Old 11-25-2013, 04:32 AM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,288 Likes on 2,444 Posts
Go with what you know and what you can do at the time, to get it back on the road. And no more 1st gear pavement messing around. lol
annaleigh
43
05-22-2018 03:27 AM
mybigredford4x4
03-16-2014 05:16 PM
5.4L to Freedom
1999 to 2016 Super Duty
27
11-29-2009 03:33 PM
Minger
07-25-2007 05:21 AM
morning town express
13
02-06-2003 09:40 AM
Quick Reply: I think I broke an axel
