I think I broke an axel
well I was messing around in the truck on the street in first gear and I got some wheel hop and then I heard a loud crack! Now the truck doesn't move when I put it in gear. I was able to drive it home by putting it in 4 wheel drive. Once I got it home I put it in first gear and the truck doest move but the drive line spins and makes some very bad noises while it does haha. Think it's an axel or rear end?
...spiders, sheared pinion teeth, or ring gear teeth. Time to open 'er up and take a peek.
I believe for a 9" you have to pull the axles out first, meaning remove all the rear brake stuff and plate that HIO is talking about.
Then the center chunk (carrier housing) from the front, it does not have a rear dif cover like a Dana 60.
You will see whats broke once you get it out, pic are mandatory at this point.
A center section can be swapped in as little as one hour.
My axel ended up being fine. Looks like this is what I might need. Does this look about right guys? I'm not trying to spend a lot of cash.
Summit Racing® Ford 9 in. Trac-Loc Differentials SUM-CTF9TRACL31 - Free Shipping on Orders Over $99 at Summit Racing
