2001 F250 radio
2001 F250 radio
Hey everyone, I am in need of some advice.
Im the very proud owner of a 2001 F250 Crew Cab.
6.8l, V10 with 434,100 miles (yes 434,100)
My question is, what other year could I get a radio and have it fit "Rufus".
I would like to use a factory radio instead of all that fancy stuff.
I appreciate you help in advance
I don't understand Rufus so take this for what it's worth.
Last summer I purchased an 02 F250 that had a cheap aftermarket radio in it. Then I remembered, long ago I had a 98 F150 that came with a cassette player which I swapped over to another Ford CD (I think it came from an Explorer) player one. As I recall, the F150 radio rode on a rail - which I had to remove to make this swap.
I found it and made the swap. Size and electrical wise it was direct fit/ no mods required. Then I dug out a bunch of old cassettes, they still worked.
If you're going to put money into it I suggest an aftermarket stereo for a couple of reasons, first the factory radios are basically junk, after market radios are usually built much better, sound better and have more features. And with the harness adaptors that are out there, are easy to install.
I upgraded from stock to a factory 6disk version once, i think in 05 or thereabouts the connectors changed if you're looking for factory upgrade. Its now sitting on a shelf in my garage *wink wink*
I used cut up metal clothes hangers to push in the holes to release the clips, but i guess those are hard to come by anymore.
Thanks for all the responses. "Rufus" is what I named the truck for now.
Yeah I thought about going aftermarket on the radio but leary since my jeep and work truck both have been broken into and tthe radios stolen...the jeep twice. But I do agree on the sound improvement. Just a shame you can't have nice things anymore.
My aftermarket unit has a removable faceplate, and it won't work without it attached. I can just pop it off and carry it with me.
I have a later model Ford 6CD unit that is available. IIRC, it came from a 2008. The CD is inop, but the radio works fine. PM if you want it.
work.truck
09-14-2015 09:48 AM
dpappen
04-24-2004 02:28 PM
