1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
5.4l 3v Spark Plug Removal Instructions
Old 09-30-2014, 09:19 AM
PaxtonShelby's Avatar
PaxtonShelby
PaxtonShelby is offline
Originally Posted by makuloco2000
The latest plugs from ford are a 2 piece design originally 3 piece. The newest plugs are SP-515 from Motorcraft and according to Ford they shouldn't have this same problem in the future.
I have a 2005 F250 5.4 3-valve. Is the SP-515 the replacement plug I want to use? I looked it up and it looks just like the plug on the RIGHT (not the left) in the photo in post #33 above.
Also - wow these are pricey plugs! Summit wants $11.97 each and Advance Auto wants over $13 a piece. Jeez! And the lisle tool is $93? Wow that seems a bit much. Do any stores loan the tool? I doubt I will use it more than once.
  #47
Old 01-31-2015, 05:15 PM
makuloco2000's Avatar
makuloco2000
makuloco2000 is offline
I am answering this very late but this is still good info for anyone stumbling upon this post. SP515 is still the latest plug yes and they are pricey. If anyone is looking at getting the lisle tool buy from amazon last I saw it was $65 not bad compared to local.
  #48
Old 01-31-2015, 05:18 PM
makuloco2000
Few notes here-
-It is best to do this while the engine is warm, so after soaking the plugs overnight blow out the rest of the solvent and reinstall coils without bolts and run engine till warm.<O></O>
-Also if your ignition coil boots are brown in color and not black you have the new plug design that does not have this issue.<O></O>
  #49
Old 01-31-2015, 05:38 PM
MDSuperDuty's Avatar
MDSuperDuty
MDSuperDuty is offline
What is the typical cost at getting this done at a reputable dealer?
Really don't feel like messing with this with the potential frustration of breaking and plug and being nagged by the family about why I need to be in the garage more. Plus the only time I could get around to this would be when I cannot afford the truck to be down. It's 10 degrees out an my garage is not heated.
  #50
Old 01-31-2015, 10:09 PM
EXv10's Avatar
EXv10
EXv10 is offline
Few notes here-
Unless they were changed at some point. Don't forget to run a ton of Marvel Mystery oil in a low tank at high and low RPMS for a week before.
  #51
Old 01-31-2015, 10:13 PM
mattymax's Avatar
mattymax
mattymax is offline
Does my 2008 F-350 5.4 3V have the bad plugs ?
Matt
  #52
Old 02-02-2015, 05:17 PM
makuloco2000
Matt
2008 was the change over year so the easiest way to tell is by the color of the coil boots if they are brown you are good to go.
Plugs are about $18 last I checked and labor will be 2.5 hours plus about .5hr for each one that breaks. So it depends on the labor rate and how many break basically. Most shops are around $100 labor rate.
  #53
Old 02-03-2015, 01:22 PM
MDSuperDuty
So total debacle, which I would question, if all 10 broke would be around $930.....
I could deal with a few hundred for not having to do it if only a few broke.
  #54
Old 02-03-2015, 04:37 PM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
My dealership did mine a few months ago. $200 flat rate for a 3V V-8 (parts included) plus $50 for each broken plug.
  #55
Old 02-03-2015, 08:40 PM
MDSuperDuty
That's good too.
  #56
Old 11-25-2015, 10:46 PM
mattymax's Avatar
mattymax
mattymax is offline
Is there a production date that was the cutoff from trouble plugs to not
Matt
  #57
Old 11-30-2015, 07:48 AM
makuloco2000
Matt
mid year 2008 vehicles and newer have the new plug design. Anything with brown coil boots and you know right away you are ok.
makuloco2000
05-23-2014 08:16 PM
wisecountybuck
2004 - 2008 F150
06-06-2013 05:38 PM
Ed
06-14-2011 08:49 PM
m@m
2004 - 2008 F150
03-11-2007 06:10 AM
hardcase72
2004 - 2008 F150
17
12-07-2005 12:56 AM
Quick Reply: 5.4l 3v Spark Plug Removal Instructions
