5.4l 3v Spark Plug Removal Instructions
Well I finally had one come in the shop recently after not seeing them for a long time. So I decided to shoot a video on the current favorite removal method that is working for us shops out there, since there are a few videos out there but they are all of poor quality. This works about 90% of the time. It seems you will usually break one out of 8 though and for that I have a new video coming out showing in detail the extraction process made simple. I hope this helps as this can be very costly. Most shops charge a half and hour more in additional labor each plug that breaks this can really add up!
So similar procedure for the 3V V10 in the affected years.... As a tech what is your thought process when to do them? Get em out asap even if everything is running fine? Or wait until it's needed? My thoughts are when I need to get this done I will be doing it during the winter when my truck is garaged. My garage is not heated but nothing freezes in it. Would the cold pose an issue with removal? This would allow me A LOT of time to work on it and not need it for anything.
TSB 08-7-6 recommends a cold engine.
CAUTION
DO NOT REMOVE PLUGS WHEN THE ENGINE IS WARM OR HOT. THE ENGINE MUST BE AT ROOM TEMPERATURE WHEN PERFORMING SPARK PLUG SERVICE. REMOVING THE SPARK PLUGS FROM A WARM/HOT ENGINE INCREASES THE CHANCE THE THREADS COULD BE DAMAGED.
https://www.ford-trucks.com/tsb/full...php?tsb=08-7-6
CAUTION
CAUTION
08-7-6*** SPARK PLUG REMOVAL INSTRUCTIONS - 4.6L 3V/5.4L 3V/6.8L 3V
CAUTION
CAUTION
CAUTION
Awesome, thanks for the video!
I should get around to doing mine one of these days. As far as I know, mine are original with 110K on them. I don't have a 3/8 impact, only a 1/2 inch, but I do have a cordless impact driver so I'll probably try using that for removal.
Sent from my HTC ONE using IB AutoGroup
