7.5 inch rear end: u-joint yoke to pinion flange bolt torque spec
I'm working on getting a factory manual for my 99 Ranger, but in the meantime I could really use the torque spec for the 4 bolts that attach the drive shaft to the flange on the pinion shaft. The bolts with the 12-point heads--not the giant nut that holds the flange on the pinion shaft.
I'll be your best friend if you can look that up for me.
1999 Ranger. 7.5 inch rear end.
Here is a link that lists torque spec in the writeup:
| Repair Guides | Driveline | Single Cardan Type Rear Driveshaft | AutoZone.com
CommanderCrzy
06-08-2015 01:48 PM
cdwoodcox
10-09-2011 04:26 PM
