Obs VC to SD VC
Old 11-06-2013, 11:45 AM
Splatts's Avatar
Splatts
Splatts is offline
Obs VC to SD VC
I'm goin to pick up my new VC's with the built in UVCH the SD style. I need to make sure I pick up the right connectors to change from the 2 plug obs style to the single SD style. Anyone know what size the wires are? Just trying to get my ducks in a row before we go to battle. Thanks fellas
Old 11-06-2013, 12:22 PM
Hussler's Avatar
Hussler
Hussler is offline
The wire stripper I used was 16 gauge.
Old 11-06-2013, 12:52 PM
Splatts's Avatar
Splatts
Splatts is offline
For some reason I always get my connectors too big. So I just want to make sure
Old 11-06-2013, 12:55 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
You need to solder any wire connections you have (as in the outside wiring splicing) to insure you have a good connection.
Old 11-06-2013, 01:25 PM
Splatts's Avatar
Splatts
Splatts is offline
I was goin to crimp them then heat shrink but totally forgot about soldering. Solder then heat shrink is te new plan. Should be doin it on Monday. Will post pics when I'm done. Thanks
Old 11-06-2013, 05:04 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
Do you have a link to where you can get them?
Old 11-06-2013, 05:12 PM
Splatts's Avatar
Splatts
Splatts is offline
I'm picking them up from napa. $77 a piece. Includes the gasket with built it UVCH and exterior VC pigtail
Old 11-06-2013, 08:01 PM
Splatts's Avatar
Splatts
Splatts is offline
Well I guess the UVCH isn't one piece with the VC. After looking at it it's would take some serious work to get it to unplug from the VC. So I went ahead and picked up a new GPR while I was there. Turn my key on, tie down a load of old poles on my truck then go in and start it ( took about 2 min or so). Started it up and it was like the truck puked. Couple puffs of smoke. It's about 55 degrees outside. So in this project I will be doin my GPR, gp's, obs to SD VC, and testing injectors, and changing the injector o'rings. Someone remind me of the few things I need to torque down and their torque specs. I was looking buy can't remember where I found them.
Old 11-06-2013, 08:14 PM
427 fordman
The rocker arms (20 ft lbs), injectors(120 inch lbs), and glow plugs(14ft lbs) are what get torqued under the vc's. FWIW, I don't bother to torque glow plugs, but you can if you wish.
Old 11-06-2013, 08:59 PM
Splatts's Avatar
Splatts
Splatts is offline
Thank you sir.
Old 11-06-2013, 09:20 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Today I put my GP's in at Glenn torque on a 1/4" wrench, LOL
Old 11-10-2013, 10:16 AM
Splatts's Avatar
Splatts
Splatts is offline
When you did your gp's did you have to worry about oil getting down the gp holes and hydro locking? I read that it can happen. I'm hoping to get the gp's changed and VC harness then start it up and check my injectors.
Old 11-10-2013, 11:04 AM
Ford4Life7.3
You shouldn't have too much oil to worry about. Some oil collects around the glow plug, you can soak it up with a rag before you pull it.
Old 11-10-2013, 11:26 AM
FI460's Avatar
FI460
FI460 is offline
As long as you said "click!" when you were doing it then it's up to spec.
Old 11-10-2013, 11:28 AM
Ford4Life7.3
This means I don't need a torque wrench for my head studs, thanks!
Quick Reply: Obs VC to SD VC
