1987 carb 460 more power
. Rebuild with hypereutectic cast pistons that bump the compression ratio up to around 10.5-11.5:1 and a mild performance cam in 214/224 - 224/234 duration at .050" lift range... add a high rise dual plane manifold... and headers with dual 3" exhaust... 14" diameter air cleaner with 3" or higher element...
. If money is no object, can add aluminum hyper heads... full roller cam setup...
BRay09
48
11-17-2011 10:33 AM
chrisf250-460
30
01-10-2008 06:31 PM
turbomont
04-06-2007 06:56 PM
jamies460
15
12-27-2005 07:22 PM
