Lost all programmed PIDs
Old 11-11-2013, 08:23 AM
99ExpyProblems's Avatar
99ExpyProblems
99ExpyProblems is offline
This morning, I drove 45 miles, then stopped for coffee. SGII was monioring ECT, EOT FMP and VLT. I got back in the truck and switched the FMP to IPR and it was blank. No numbers. Scrolled thru and noticed many more also blank. Unplugged from OBDII andI plugged in again. still blank. All pids that I programmed are blank including EOT that was working until I switched pids. Any ideas?
Old 11-11-2013, 08:34 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Ouch! Sounds like it had a brain cramp. Might be a problem with the unit.
Old 11-11-2013, 08:52 AM
BLADE35's Avatar
BLADE35
BLADE35 is offline
if you can reset the SGII
I get that if If I let the SGII power On First before I start Truck
If I start truck and let it start on own works Great IDK why
Old 11-11-2013, 09:37 AM
99ExpyProblems
lol@reset.... Geez. I don't want to program all the xgauges again.
Old 11-11-2013, 09:44 AM
jswartz84's Avatar
jswartz84
jswartz84 is offline
This happened to me a few months ago, I unplugged it and left it that way for a half hour then plugged it back in. It worked fine after that. I too didn't want to reprogram mine but that's where I was headed if it didn't work.
Old 11-11-2013, 09:46 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Happens to me often when I plug/unplug it. Try plugging it in with key off and letting it go to sleep before you try starting the truck.
Old 11-11-2013, 10:12 AM
99ExpyProblems
That was the 'idea' that I had too. It's unplugged since I got to work. I'll check it again at lunch. I wasn't thinking it was going to work though, because I assumed it had a battery backup that allows it to store the programmed xgauges. Fingers crossed it works like yours did! lol
Thanks, I'll try that too.
Old 11-11-2013, 11:04 AM
99ExpyProblems
Went out at lunch time and plugged it back in and BAM! They all work!
Old 11-11-2013, 12:21 PM
jswartz84's Avatar
jswartz84
Sweet, I'm glad it worked for you. Also glad that I'm not the only one its happen to
Old 11-11-2013, 03:47 PM
acf6's Avatar
acf6
acf6 is offline
Yeah mine does it all the time, sometimes they just randomly go blank
Old 11-11-2013, 05:08 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I have found from time to time mine will lock up
and if you unplug it and plug back in you have --
for the displayed numbers. Shut the truck off
let the SGII go to sleep on it's own and restart.
Problem gone.
Sean
Old 11-11-2013, 05:32 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Its been awhile but I don't think you Loose X-Gauges with reset
All I ever Lost was the MPG Info from the Reset
Hope Im not getting it confussed with switching SGII from Car to Car
Old 11-11-2013, 05:53 PM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
Mine has done this about 3 times over the past 8 months. For me, turning the truck off and restarting brought it back to life. Apparently it is common?
Old 11-11-2013, 07:46 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Me too. I woke up sg2, and was entered new xcodes, turned key on with sg2 awake and it could not display anything. Turned key off, let sg2 go to sleep, turned key on and started engine, i woke up sg2, all happy again.
I suspect, having the odb2 bus go active with the sg2 awake gets the bus interface out of sync and the sg2 can't recover without restarting.
Did you ever wonder what signals the sg2 to "wake up" on it's own once engine is running?
Sent from my Sprint PC36100 using IB AutoGroup
smblokford
2009 - 2014 F150
04-25-2013 01:12 PM
BLADE35
06-16-2012 09:44 PM
bigred66
01-25-2012 05:47 PM
Quick Reply: Lost all programmed PIDs
