1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Radiator water hose leak
Old 11-10-2013, 11:54 AM
Wrench Bender 117's Avatar
Wrench Bender 117
Wrench Bender 117 is offline
I have a 2010 F-250 6.4L Lariat that has a small water leak at the point where the lower radiator hose connects to the lower outlet on the water pump on the drivers side of the pump. The hose appears to be attached with some sort of a snap ring and the hose is loose and leaks when shaken. How do I tighten up the hose to stop the leak? There is no coinventional screw down type of hose clamp????
Old 11-10-2013, 12:29 PM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
You buy another hose. That is a quick disconnect. Your current hose is that of a single o-ring design to connect to the water pump.
Getting a updated hose will have the double o-ring design.
Just lift the wire and pull to disconnect.
MsKitty
06-19-2021 01:51 PM
granny_rocket
01-29-2016 05:04 PM
abyars111
10-30-2013 11:58 AM
baby2000
20
11-14-2009 08:38 AM
Fourwheelinj1
04-16-2007 09:09 PM
Quick Reply: Radiator water hose leak
