Shocks for a 1950 F3
It's time to hang some new shocks on the old truck. The old ones still have paint on them, but they're factory original, and don't do their job anymore. Anyone have any ideas whether I should just go for repacement shocks similar to the original, or should I be upgrading? PS There are only front shocks; none on the back!
on
I would go for the new shocks not the original type. You should get a better ride that with the original type. BTW you could have rear shocks if you wanted. Just get a pair of shock mounts of a 48-52 F-1 and they will bolt on. Weld two home made brackets of the axle to get the lower shock mount. Bolt on the shocks and way you go.
Nathan;
Thanks for the advice. I'll pull a shock and take it in to a supplier. I'll measure bolt to bolt as it sits now. As for the rears....there's like 24 leaf springs on each side...I'll need a pretty heavy duty shock to do anything.
I took a peek at your site....well done. KB
Originally posted by KEITHS 1950 F68
Nathan;
Nathan;
DieselCamper
07-05-2016 06:26 AM
1950FordF1
02-16-2016 02:09 PM
jdhudall
05-18-2015 09:32 AM
