5th Wheel Towing
5th Wheel Towing
I currently have a 24' Bumper Pull Toy Hauler. I think I'm about 9,000 pounds fully loaded. I'm thinking about buying a 40' Fifth Wheel Toy Hauler. I'm driving a 2006 F-250 6.0 Diesel 4x4 Crew Cab Short Bed... The Trailer, Loaded, will be about 16,000 pounds. Anyone else out there dragging around a rig this big? How does it tow? How does the 6.0 handle it on hills? I'm told I should Install Air Helper Springs (Air Bags) on the rear and also use a "Slider Hitch"...
Steve
ryanf77,
I pull a 33 5er with a loaded weight of about 12K I have a 15K slider but have never been in a tight enough spot to use it. The truck pulls it with no problem the 6.0 is a pulling machine. I think your problem, if you have one, is gonna be pin weight. I think the airbags will help but that kinda weight really belongs on a duelly in my opinion. Your looking at 2400 lbs on the pin based on 15% of the trailer weight. (15% given as an example) Again...my opinion only but pullings not the issue.
ryanf77,
I pull a much smaller 5r@31ft and right at 10k lbs. I would suggest loading up the truck with any gear you plan on taking, including passengers and a full tank of fuel and hitting the scales. With those numbers and the data plate on the door jamb you can figure out what you can tow (according to Fords engineers). Don't forget tire ratings and rims also if they are aftermarket. Don't trust the sales people at the RV place to help you much. When we were shopping I asked the sales person and he looked out the window and said "you can pull anything we have on the lot." There are some charts and figures on the Ford website with general max figures but checking your rig on the scales is worth the effort. I found I could tow 15,400 lbs (forget the max pin weight) with the truck in my sig.
The slider hitch is related to the 41' part of your plan. In a tight situation you can roll it back and the front cap of the camper will clear the back of the cab, allowing you to turn much tighter. Even with my 31' I've used it a couple of times. In the campgrounds along the coast, real estate is at a premium and sometimes they really pack 'em in there.
I agree power shouldn't be a problem but don't forget braking. Coming from travel trailers to a 5r I noticed a tendency for the rig to "porpoise" a bit on bridges and large bumps. I think loads on the hitch, frame, and truck suspension are at their highest then.
With the toy hauler, you will need a good plan on loading the toys and consider their weight also. It's easy to overload the trailer or truck with that much room.
Generally, it sound to me like your plans will bring you very close to max weights and would be easy to overload without knowing exactly where your weights are at. There's ALOT to know on this subject and I'm no expert but the main thing is to be safe and have fun! I suggest checking the RV forum here at FTE, lots of good info there!
I've been researching my own 5er options. I agree with needing to weight the truck as it sits now, add in everything you may want to take, and weight it again. For the 5er I was looking at I could expect to see the pin weight top out my base weight easily. I use the 15-25% as quoted in the Ford Tow guide. With 25% I'm over my GVWR by 1000 pounds. To make that work I would need to spend a day at the scales moving stuff around in the trailer to shift the CG.
In the end do the homework two and three times.
Steve
Steve
