To Cam or not To Cam
so im thinking about caming my 96-97 351W I'm gonna use a crane 444232 I would like to know if i need different valve springs or if i can just use the stock ones.. and what are the specs (or link to the specs) on the stock cam so i can look at the differences. Thanks
http://www.summitracing.com/parts/crn-444232/overview/
wrong cam
you have a roller block.
Make: FORD
Beginning Year: 1969
Ending Year: 1993
Engine Type: V8
Liter: 5.8
CID: 351
Engine Size: 5.8L/351
Here, figure I start ya off in the right foot.
http://www.summitracing.com/int/sear...rder=Ascending
Make: FORD
Ending Year: 1993
Engine Type: V8
Liter: 5.8
CID: 351
on
The stock cam in your '96 is a steel roller so you don't want to go backwords to a flat tappet like that Crane, instead look at the Crane 2020(444211) roller and then you won't need different lifters or pushrods but upgraded springs are always a good idea and likely necessary with the valve lift this cam generates.
The stock cam in your motor produces 0.422"/0.445" lift at the valve and has 254/266 degrees advertised duration.
on
Given that this cam generates 0.530" lift you don't want to use 1.7 rockers the stock 1.6 rockers will be fine, you could substitute 1.6 roller rockers but it's a bunch of money for very little gain. Aluminum roller rockers fit under the stock truck valve covers with a little messaging of the oil fill and PCV baffles while steel roller tipped rockers will fit with no mods because they're physically smaller.
Based on my experience with the Crane 444232 I'd say this cam will run just fine on SD.. the two have very similar specs.
70torino429
05-15-2009 10:07 PM
83f350
15
03-13-2008 08:27 PM
