Heater/blend door trouble shooting
Over the last few days I have read several threads about heaters not working and blend door replacement. My '02 4.6 F-150 has 250k+ miles and I've always done regular maintenance on it. With the cold front moving in I've noticed that the heater is not blowing hot air. I flushed the radiator and flushed the heater core several times to make sure the core was not clogged. I also replaced the upper radiator hose because of the "crunchy" sound when squeezed. I also replaced the thermostat. Still the heater is not blowing hot.
I assume like many others that the blend door needs to be replaced. My question is do I need to replace the door only or the door and the motor (actuator)? I guess I need to test the motor before buying a new one.
I saw a video where you remove all the components on the transmission hump and can actually stick you finger in the motor opening to see if the shaft has come apart.
Am I on the right track here?
How do I check just the actuator to see if that's the problem or if the door itself is the problem?
If that checks out OK, it may be the bottom slot on the blend door is cracked. The only way to get at that is to pull the dash. I would think if you had the actuator off that you could stick something up into the bottom pivot on the blend door and open it up. At least you would have heat then.
Gonna replace the actuator tonight.
I'm curious about the temperature control **** itself though. It has a screw in the back of it so that just that switch can be replaced. I guess I'll find out when I hook the new actuator to it.
Lukester1980
1997-2006 Expedition & Navigator
12-17-2006 02:49 PM
