gear ratio
gear ratio
I have a 49 f1 with a 239 flathead and a 4 in the floor. I wanted to know if i change the rear to a 9" what is a good gear ratio. Looking at a rear out of a 65 f100 the guy said its a 3:70. Also would i need to change anything for it to work? I dont know about things like this never did a swap. Thanks again guys for any help.
Brian
Brian
I have a 52 with a HD 3 speed, with a 1 to 1 top gear. When I bought the truck it had a 9" with a 3 to 1 final. You could run over 80 on the freeway but it bogged down on every hill ( I live at 4000' elevation). I changed to a 3.5 to 1 and now the truck has a max of 75-80 and has much better power up the hills. This is with 27.7 inch tall tires. Hope this helps.
There are ratio calculators on the web where you can put in the tire diameter, rear axle ratio, transmission gear ratio (1:1 in high gear unless you have OD) and speed and find the engine RPM, or put in the desired engine RPM, speed, and tire diameter and solve for rear axle ratio desired. The Ford 9" has the most gear ratio ring and pinion sets available than any other rear axle. What ratio you want may depend on the type of driving you do. 3.7:1 is likely to be a good ratio for around town and occasional trips of 100 miles or less at 55-60 with moderate economy. Don't buy a used R&P set unless you get it in their original carrier.
Do an Advanced Search on here, there are hundreds of threads on this topic, including what years fit, and different people's experiences. I have a 9" and tried it with a 3.25 at first. I'm at 5300', and there are some good hills. It was awful. Taking off from a light took a lot of clutch slipping, going around corners in town in 2nd also required clutching. No guts on hills. Changed to a 3.50 (with 28" tires) and all is well.
Here is a good gear ratio calculator for you. Doesn't tell you what the power will feel like though, that's why I let you know how mine runs.
Engine RPM Calculator
BTW the only accurate way to measure your true rolling diameter is to make a mark at 6:00 on your tire and another next to it on the pavement. Roll the truck forward one wheel revolution and make a mark on the pavement there. Measure between pavement marks and divide by Pi (3.14159). Advertised or calculated diameters are not accurate at all.
Anafiel
12-11-2011 06:37 PM
Broomfieldbum
07-26-2009 09:07 AM
calazo
06-02-2004 08:17 PM
