Vehicle Speed Sensor Location
Also posting here as my question falls in both forums.
https://www.ford-trucks.com/forums/1...-location.html
I have a 93 F350 Crew Cab 7.3 Diesel 5-speed with what seems to be a Sterling 10.25 rear diff. I am told the ABS/speed sensor should be on top but I don't see it. Any ideas?
You can see the plug circles in one of the photos. I don't see where the sensor would go. The rear end was swapped. I assume with an older model without the sensor. What are my options? Can I pull speed from the transmission? Does this look like the 10.25 diff to you guys?
arkiados
18
10-23-2013 07:53 PM
Jrock909
04-29-2007 07:03 AM
