EGR Delete questions....
That's my exact setup see Sig below
Truck runs Fine
about 27K since and NO CEL!!
Before I deleated the EGR Cooler I had the EGR Valve Unplugged for awhile and Never got a CEL or any DTC
Try this^^ and see what happens see if CEL Turns on then see what it is for if it even does turn on
03 are less likely to trigger CEL from this
Just make sure an EGR valve is still plugged in so the engine fan still operates correctly.
Josh
Ok I have been looking at EGR delete kits and have a few questions!!
1) WTF is sinister so proud of their kit?
2) the exhaust pipe in the kit where does it go? I am a newb to Diesels. Does it replace the EGR cooler?
3) what kits are to be stayed away from?
4) If I have a bad egr valve and I leave it plugged in, will I still have a drivability issue?
I've been happy with my IPR Gen 2 delete kit.
Sent from my mind thanks to the Internet and an app.
They are????
Preformance machine
IIRC PMM Manufacture
Not from To Much Exhaust gas
But you could have Fan Issues ect...
So the exhaust pipe replaces the up pipe that the EGR cooler attaches to! Is there a gasket or 2 that is needed?
I feel so out of my element on this stuff, but refuse to part with my hard earned $ for labor! lol
I purchased the Sinister kit along time ago...it came with the up-pipe gasket.
If I were to do it again I'd use an IPR Gen2 Blem....cheap and better design.
Agree with Blade35...if the egr valve is in fact bad, I'd replace it and keep it plugged in. Have you confirmed that it is bad? Maybe just needs a good cleaning and a new gasket kit.
I would also suggest taking out the butterfly in the intake if it has one. (03-04). Simple to do and even if the ECU commands it closed it is now just turning a shaft. I am surprised it is never discussed. Before I added a tune to disable mine would close pulling a hill. Motor would flatten out. found later is was the butterfly.
