Is there a special trick to removing the EGR valve?
Been trying to pull this thing. Get the connector off and remove the bolts but I can't get it out. Not even with a small flat pry bar. Is there some trick to getting this thing out that I'm not aware of. Didn't see anything special in the tech folder but then again there's so much stuff in the tech folder I could've overlooked it. Any tricks or special instructions? Does it need to be cold or hot?
Thanks
Bill
There are YouTube videos for removing the EGR. Do a search, watch videos and they show how to remove easily. Don't have the links. Believe one was by dieselteckRon. His are always pretty informative.
I just get that bar under one of the bolt tabs and pry it up, very simple. I believe dieselteckron uses one of the other bars in that set to get his out.
I always use a old coat hanger and pry bar. Just turn the egr valve so the bolt holes are open then run each end of the hanger through the holes and twist with pliers. Then using a 3 foot pry bar lever against the alternator bracket and give it a couple of jerks upward and she'll pop right out.
GOT IT! Finally. Thanks to you guys that took the time to help me out. Couldn't have done with out your help. Would've given up and taken it to somebody.
Thanks
Bill
Of topic here but, one of you guys mentioned an EGR cooler delete. What about just putting a block off plate between the exhaust and the EGR cooler. Seems very inexpensive and simple.
