Carburetor and exhaust manifolds
1965/67 F100/350 352 & 1973/74 F100 360 left exhaust manifold designed for separate heat riser valve that fits between manifold and inlet pipe.
Left side manifold same: 1965/67 F100/350 352 / 1973/74 F100 360.
Right side manifold same: 1965/67 F100/350 352 / 1968/76 F100/350 360/390.
1965/67 F100/350 352 2V carb basically same, used with manual choke. Some 1968/69 F100/350 360/390's also came with manual choke.
I have a set of exhaust manifolds that I removed from a 66 352; the driver side has the butterfly/heat riser. They are pitted, but not cracked. You can have them for the cost of shipping -- otherwise they will probably be included in a scrap iron run. I am in western North Carolina (zip 28806) so use that if you wish to investigate shipping cost.
I have seem the manifolds listed by some of the repop places... they range from $100 to $150 each====heat riser not included.
I also have a holley (2300 I believe) 2 barrel I removed from the same engine (I do not believe that was stock); it has been reconditioned.
Gavin
Gavin
rockittsled
12-23-2012 05:19 PM
BigMikeUGA
03-05-2012 11:49 PM
