Used Truck
Used Truck
I found a 2008 f250 at a local car lot for 7800. The guy said it needed injectors. I asked him why he thought that it needed them. His answer was because it smokes bad. We started it and let it idle. Engine was kinda noisy and smoking a little. He said it would get worse. I revved the engine and it smoked more and you could smell oil. Guess my question is will the injectors do this or is the engine shot?
These trucks are extremely complex and expensive. Hope this helps.
However, if you can get a Ford tech to confirm what is actually what wrong with it, it might not be such a bad deal if its in nice shape.
Just keep in mind and engine is over $12K
Yeah, if you pay 8 and spend 12 you have 20 in a truck that should bring a couple thousand more than that. Question is, can you fix it for 12,000? I would say if you get past about 22 thousand you might as well look for one that doesn't need repair and save all the aggravation. It's now a 6 year old model and has a lot of detractrs especially if it was an early build. Unless you are a very good shade tree guy and want a project. It would probably be a great project with a nice pay off at the end. What you need is a brother in law with a big diesel shop. Good luck whichever way you go.
Here is the link to web page. He has cleaned it up some since these pics were posted.
2008 Ford F250 Diesel FX4 Crew
Sounds like a good deal and a fun project as long as it just needs what the sales guy says. My scare with this type of purchase, and i am a mechanic, is if they neglected the motor...what else major did they neglect...it's at a car lot selling it after all.
My advice would be get it to a ford shop and have them go over it for you...might cost you a 100 bucks but could save you thousands...just remember that with this type of project, once you start there is no turning back!
Good luck and have fun which ever way you decide
