1977 F100 Dana 44 to 9" swap???
Old 10-01-2013, 03:32 PM
medino03's Avatar
medino03
medino03 is offline
My truck is a 1977 F100 Shortbed and currently has a Dana 44 in it. I want to switch over to a 9". Will the driveshaft work without having to change yokes or shorten/lengthen the shaft? Is it a direct swap?
Old 10-01-2013, 07:17 PM
lurch460's Avatar
lurch460
lurch460 is offline
What axle are you swapping? Front should be a 44 rear a 9".
Old 10-01-2013, 07:51 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
It's not very common but Ford did use the Dana 44 for the rear axle in some applications.
I think the OP wants to swap a rear D44 for a Ford 9".
Old 10-01-2013, 08:17 PM
Jdeshler's Avatar
Jdeshler
Jdeshler is offline
This is a first for me.. ill be watching this one
Old 10-01-2013, 09:14 PM
medino03's Avatar
medino03
medino03 is offline
That is right. It is the rear axle.
Old 10-01-2013, 09:24 PM
mikeo0o0o0's Avatar
mikeo0o0o0
From what I've been able to learn, it was pretty much limited to the '77 model year and had the axle code 46 on the warranty plate.
Old 10-01-2013, 09:27 PM
ShaneNP123's Avatar
ShaneNP123
ShaneNP123 is offline
My '79 F100 also has the D44 rear with 2.72 gears. good for highway cruising with no overdrive.
Old 10-01-2013, 09:32 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Ah, so it was more than one year, thanks for the info.
Old 10-01-2013, 09:53 PM
vic_v8's Avatar
vic_v8
vic_v8 is offline
You'll probably need a different U joint.
Old 10-02-2013, 12:29 AM
Jdeshler's Avatar
Jdeshler
Jdeshler is offline
Good luck at the parts counter asking for a combination ujoint lol!! (If youll even need one) They have them but both times I have asked its pretty much left them confused and me digging through the stash in the back
Old 10-02-2013, 01:25 AM
mikeo0o0o0's Avatar
mikeo0o0o0
According to the parts catalog, the D44 rear takes a 1310 u-joint. There are a lot of 9" rears that take a 1310 also.
Old 10-02-2013, 06:42 AM
medino03's Avatar
medino03
medino03 is offline
What about the length from the center line of the axle to the center of the yoke?
Are they the same?
Old 10-02-2013, 09:09 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Are they the same?
This is just an educated guess but I think the Dana driveshaft will be about 2" shorter than the Ford.
I'm taking a guess on the specs of your truck. I used '77 shortbed 2WD w/ 302 automatic. The parts catalog shows the Dana driveshaft to be 53 9/16" long and the Ford driveshaft for the same specs is 55 17/32".
That's a 1 31/32" difference in length. The catalog also shows that the both shafts use the same u-joints and slip yoke.
Old 10-02-2013, 09:12 AM
grnlzrd's Avatar
grnlzrd
grnlzrd is offline
Professional Lurker
No help to the OP, but I have the same thing in my '78. Love the 2.72 gear for mpg. Haven't driven enough since the intake/carb swap, but I used to get about 20 mpg. I also have a '77 parts truck with the 9", not sure of the gears, but have thought about keeping the axle around as a spare. I assumed it was a direct swap.
Old 10-04-2013, 07:17 AM
cooktimj's Avatar
cooktimj
cooktimj is offline
My '77 has a Dana 44 rear end too. 302/C4/Dana 44.
Anyone know why these rear ends were used instead of the more common 9" rear? Fuel economy? Cost? Short supply of 9" at times?
Just curious.
Quick Reply: 1977 F100 Dana 44 to 9" swap???
