BIG RED's build thread
#588
on
1 Post
Thanks guys! I got the IC piping mocked up tonight. I'm gonna tack it together and then weld it all up once I get the trans in and the engine sitting exactly where it's gonna be. I've got it real close now I think, but I don't want any surprises later. It may need some minor adjusting.
Too bad the green masking tape wouldn't hold it.......It would be done! LOL!!
#592
on
1 Post
I made bungs to weld in the pipe. I was gonna put some in both sides in case I ever want to do water/meth or something. I thought about welding one in the "Y" just for whatever. Might be good to have them in the hot side, cold side, and the "Y" to experiment with moving the map and boost lines around for comparison. I can just plug the ones I don't use.
#593
#597
Looks good Bill! You're probably going to want to add a SD style oil filler riser to make it easier to get the juices flowing, though.
#600
