Turn signal flasher
09-27-2013, 01:48 PM
on
Turn signal flasher
Hi, I searched the forum, but had no luck so far. I own a 1977 F-150 camper special with a 460. My turn signals don't work and after checking the fuse I purchased a new flasher for it. I looked everywhere (i guess not in right spot), but I can not locate the turn signal flasher. I have found the hazard flasher that was hanging right in front of the fuse box, but I had no luck finding the turn signal flasher.
Thanks in advance for your help.
09-27-2013, 02:07 PM
on
Found it right after I posted this thread. Unfortunately the replacement flasher did not help. I guess it's the switch.
09-27-2013, 03:03 PM
on
OK, I'll bite. Where is it? The hazard can is in plain sight, as you noted, but I just had my head under the dash and did not spot another.
09-27-2013, 03:44 PM
on
It's tugged away on the left side, right below the light switch. I was not able to see it, but could feel in to the left below the light switch.
09-27-2013, 04:14 PM
Quote:
Originally Posted by
sinmike
I know you said the fuse is good, but do you actually have power at the flasher?
09-27-2013, 06:34 PM
on
I will check it tomorrow. Thanks for the advice.
09-28-2013, 09:40 AM
on
O.K. The flasher has power. Unfortunately I am not an electric guy to figure out the next steps. Any help would be greatly appreciated. Thanks.
10-09-2013, 09:16 PM
on
10-10-2013, 06:26 AM
There are TWO different flashers. One for the turn signals, t'other for the 4 way emergency flashers.
Left (lower ): 13350 T/S flasher / Emergency flasher located adjacent to instrument cluster.
Metdawg44
49
05-10-2020 08:15 PM
Virto
10-09-2007 11:53 AM
Benny2002
04-12-2007 10:45 PM
ChurchBuilder
10-27-2006 09:00 PM
earl964
06-25-2006 07:00 PM
