Jacking the F250
Jacking the F250
Dumb question here. I haven't had to jack my truck yet, which is good because my floor jack won't even touch the frame when fully extended. I just need something to get a wheel or two off of the ground at a time and I am wondering if a 4 ton jeep jack would do the trick. The bumper seems pretty darn heavy, can I jack it from the front and/or rear bumper?
The rear bumper bolts on with a slotted connection to allow for adjustment. It can't take the weight and can/will pop the bumper up if you lift from it. Then it will be crooked and can damage the tailgate when it is lowered.
Lift from the axles whenever possible. Hi-lift type jacks are very sketchy and should only be a last resort.
on
