engine replacement
engine replacement
This my first post.
I have a stock 55 w/original 223 6 cyl, 3 spd manual trans, and original rear end. The engine seems on its last legs at times. What would the group recommend for a full replacement (6 or 8, auto trans) or for each component? Ideas on ballpark cost for all or each?
Thanks.
Thanks.
This my first post.
Thanks.
Thanks.
Thanks. I figured 2 to 3k. I know my wife would like an automatic tran. Amy suggestions for a basic if I go that way. If I do I would guess a compatible rear end would be needed. I know this is a major operation, but it would be helpful in planning dollars and time. Just feeling my way thru the planning.
My questions to myself now,hind site is 20/20. Is it going to be a weekend driver,once a month, 2-3 times a week and so on. I put a 383 sbc,tb350 tranny re-built,serpentine belt system,eldebrock 650 carb,425hp. It has less than 5k on it and now I want to sell it and start over. I love to drive mine,but the gas is killing me. I want to put in a LS2,3, or 7 in it and get more hp,but with better gas mileage and more reliability. So my point is for you to decide which way you want to go first,then you can figure out the funds. I was in to big of a hurry to get it on the road,instead I should have waited to find the right engine for my purpose. L8R ZFLASH
It depends on your abilities... If you can find a donor vehicle cheap enough you will get all the brackets, wiring harnesses, and small bits and pieces that can be a huge pain with an engine swap. It also helps if you have some fabrication skills, making motor mounts, transmission mounts, etc. instead of buying them can save you quite a bit. A 302 and AOD fits into these trucks pretty easily, and parts are easy to find for the swap. Don't forget about the driveshaft, I had to buy a used one and have it shortened, around $150 including new u-joints.
Welcome from a neighbor just up the road and over the hill (Whitesburg, KY). I used to live in Bristol. Let me know if I can help out. reed1951 is just down the road from you. Shop around and see if you can get some help with the engine over there. It might not be a lost cause. Plus it's gonna be winter pretty soon, and you've got time to figure out your options.
Bottom line, the flatty will be headed for the shop this winter
I went with a Ford Racing crate 302 (306, 340hp, 350tq) and a New/rebuilt AOD. Conversion was easy as I was already 12v with my Flathead. Just had to weld in new motor mounts and a new cross memeber for the AOD and a new drive shaft. AOD allowed me to use my stock Dana 44 with the 3.92. However it rebuilt it and converted it to a posi. No cutting of the cab or floor was needed. You can go on the cheap buy buying a used motor and AOD.
I have major oil leak problems (have replaced head and exhaust gaskets) and especially an idle problem where it dies when coming to a stop and clutch is depressed (which causes my wife not to wish to utilize the vehicle). Had to replace carb (which was really hard to find) which had major vac leak problems (a carb kit and float rebuild did not do the job) and now replacement one is doing the same. I have run out of ideas on adjusting the carb. Not sure if distributor should be replaced, but seems time to consider how much time and money needs to be spent or try to go with something else under the hood which would probably mean something else along all the drive train. I am just considering my options for a winter project but money is tight as it is with all of us. I am not the brightest candle out there and am fairly new to restorations and any ideas/suggestions will be greatly appreciated.
