Spare Tire Sizing?
My spare is not as big as my 4 tires. If needed, I would use it to get to somewhere that can repair or replace the flat tire.
Differentials are designed to allow tires on the same axle to rotate at different speeds, even LS differentials.
I would not run 1000 miles with different sized tires on an axle, but 50 or so to get to a shop is OK.
If you can't get to a tire shop within 50 miles, you went into the outback unprepared.
carl2591
17
03-19-2016 11:13 AM
purplewg
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
16
10-22-2013 09:55 AM
