Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
76 F100 wheeler build
Old 09-16-2013, 10:38 PM
lucky_thirteen's Avatar
lucky_thirteen
lucky_thirteen is offline
I'll stop plugging up the other thread and make my own
Started like this, had a 302/np435/dana 21
Built a rear bumper for it shortly after
After a while it got 35's, 4.56 gears, and a rear spool
Got a different daily driver, and this wend under the knife. 63" Chevy rears mounted under the frame, ho72 axle with 14 bolt guts, and some 42's
Old 09-16-2013, 10:39 PM
lucky_thirteen
Yarded this junk out of the front end, and built a front bumper. There's a winch in there, just need to order a fairlead and cut out the hole.
New running gear. 4sexty/np435/203/205
Got the dana sexty set under it, the steering box mounted, and the three link under way
This little guy doesn't let me have too much time to work on it
lucky_thirteen
Making some progress, things are tight under there
Clicky
Getting some welding done on the front
lucky_thirteen
Built me a diff cover. Hopefully the hydro assist ram will show up tomorrow so I can get that mounted
Old 09-21-2013, 02:15 AM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
This thing is looking pretty badass, those tires are CRAZY! If you ever get it road worthy you should swing by one of our meets with it. Your location is only in Black Diamond right? Thats not too far from me.
Old 09-22-2013, 11:43 PM
lucky_thirteen
Not far at all from ya. I plan on dragging it out to a meet once it's done
Found a little bit of time today, got one side of the ram mounted
Old 09-23-2013, 01:26 AM
GruesomeJeans
welded to the diff cover? Can I ask why you did that?
Old 09-24-2013, 12:18 AM
lucky_thirteen
Easiest place to put it.
Cut out and tacked the other end on today
Old 10-21-2013, 12:18 AM
lucky_thirteen
Slowly been picking away at it. Front has a bunch of flex left, but the fenders need to be chopped more first.
All tucked safely back in its hole
Old 10-21-2013, 03:38 AM
GruesomeJeans
Those tires are crazy on there. I like a lot of sidewall on my tires so those look awesome.
Old 10-22-2013, 12:11 AM
oddfordjunkie's Avatar
oddfordjunkie
oddfordjunkie is offline
What do you have on the passenger side frame rail mounted by the shock?
Got a picture of the engine cage/shock mount?
How are the road manners?
Do you have a thread on your Truggy?
Old 10-22-2013, 07:57 PM
lucky_thirteen
It's a glorified bump stop. They have 4" of travel and are nitrogen/oil filled. Basically a mini shock that gets progressively stiffer as it compresses.
I'll have to get some pictures of the shock mounts. Still has a ways to go before it gets driven. I ended up selling the truggy when my kid was on the way. I'll post up a link to the new owners thread
Old 10-23-2013, 11:03 PM
lucky_thirteen
Made mounts for the power steering pump. I think I ordered enough junk to make it steer too
Old 10-23-2013, 11:57 PM
oddfordjunkie
Had a thought it might be a bump.
Have a kid on the way myself and trying to get as much done on my CC as I can before the little one shows up.
Cage/shock mount looks great (like all your work I've looked at) probably just be the angle of the picture but looks like it's over the top of the oil fill, would be a pain.
Old 10-31-2013, 01:52 AM
lucky_thirteen
Thanks
Little people definitely manage to suck up most your free time, absolutely worth it though. The cage is over the oil fill, it's high enough above it that it shouldn't be too annoying.
Still waiting on a few fittings for the hydro assist to show up. But I managed to mount the reservoir and get it plumbed, drilled and tapped the steering box, built a steering shaft, built some exhaust, and got the fan mounted
Quick Reply: 76 F100 wheeler build
