03 6.0 Diesel problems
Old 09-16-2013, 01:41 PM
rockenr's Avatar
rockenr
rockenr is offline
My 03 starts fine when cold but runs like crap untill it warms up. After it warms up it starts like crap. When it's cold I can barely get the rpms to 2500 in 1-3 gear. Gets up to 3000 rpm in 4-6 then when it warms up things work better but starts hard. Took it to ford and got the egr error code. Replaced it, no help. Heard it could be a high pressure oil leak. Would this cause all the symptoms I've mentioned. thx
Old 09-16-2013, 04:39 PM
BigOl04's Avatar
BigOl04
BigOl04 is offline
sounds almost like a oil or inj problem. oil press controlls the inj.. do you have a oil press gauge?
Old 09-16-2013, 04:44 PM
Magnus E's Avatar
Magnus E
Magnus E is offline
Just have to ask...aftermarket oilfilter cap?
Old 09-16-2013, 05:35 PM
Tom's Avatar
Tom
Tom is offline
Hi rockenr,
I'm going to move this down to the 6.0L forum, you should get some more help down there.
Old 09-16-2013, 05:58 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Rockenr: Please post the specific code you got. It will help with diagnostics. If you can't remember it then most auto parts stores can and will scan it for free. Yours doesn't sound like a high pressure oil leak to me. Usually an HPO leak won't let it start or be very difficult to start.
Old 09-17-2013, 10:47 AM
rockenr's Avatar
rockenr
rockenr is offline
Threw code P0404
P0404 code came up. Pointed to egr valve. Replaced with rebuilt. No change.
Old 09-17-2013, 10:49 AM
rockenr's Avatar
rockenr
rockenr is offline
No just the idiot oil gauge that shows a little less than 3/4 the way up.
Old 09-17-2013, 10:51 AM
rockenr's Avatar
rockenr
rockenr is offline
Just had the oil cap replaced when I took into a local garage. I'm sure they got the cap out of car quest.
Old 09-17-2013, 10:53 AM
rockenr's Avatar
rockenr
rockenr is offline
It starts hard when hot but when it's cold it fires right up usually. When hot about 10 seconds and sometimes I have to try it twice to go.
Old 09-17-2013, 01:06 PM
POORBOY1964's Avatar
POORBOY1964
POORBOY1964 is offline
It really does sound like a HPO leak do you have a way to monitor the motor?
Old 09-18-2013, 02:33 PM
rockenr's Avatar
rockenr
rockenr is offline
No Guess it's back to the ford garage.
Old 09-18-2013, 02:42 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
Cheaper to go to Auto Zone and buy a Scan Gauge!!!!!
Old 09-18-2013, 03:00 PM
npccpartsman
It's possible that the oil is leaking out of the filter housing because of an ill fitting filter (non-OEM fiter). They've been known to cause starting issues.
91 7three
1999 to 2016 Super Duty
08-08-2019 08:46 AM
mpatton99
02-20-2016 05:26 PM
memarkers
01-03-2016 09:04 PM
deeslfxr
08-30-2014 11:34 PM
Edigan
03-31-2008 05:32 PM
Quick Reply: 03 6.0 Diesel problems
