Clutch info
Personally, I don't install any organic style clutches when I do Valair clutches. They have never recommended that I install one in anything either, even in completely stock trucks. I have driven a truck with one and they are still a little bit grabby, just not quite as bad as the kevlar/ceramic. I never had any problems backing up trailers in my 2wd with any of the clutches I've run. You just need to know what your doing.. It's not terribly complicated..
Mike, that clutch will slip, but again... You have to know how to drive it. Many figure out pretty quickly that they cannot take of from an idle like they used to, but instead they have to rev it up to around 800-1000 rpm in order to take off smoothly. Slipping the clutch at an idle will cause it to be very rough. My ceramic double disc is pretty close to engaging like the kevlar/ceramic, but my double is just a touch smoother when slipping the clutch at idle.
Travis pretty much nailed it. "Slipping it" is a relative term with this clutch It's a different animal and takes some getting used to. Like Travis said the key is to get the RPM up a bit, then it's smooth like butter. Not always easy to do when backing a trailer though.
PS Travis, remember that noise issue I was texting you about a while back? It's not gear rollover, but it is coming from the trans. As best I can figure its basically just the sound of the gears rolling against each other. The old pour an extra quart in through the shifter hole trick would probably clear it up.
Personally, I would have gotten the kevlar/ceramic, but if you're going to be keeping the truck stock, maybe just a chip or something down the road then the brass woven organic should be fine. If you ever plan to upgrade injectors down the road, the kevlar/ceramic would have been the better choice.
Yeah, I remember. By the description you give in this quote, it sounds EXACTLY like gear rollover. Gear rollover will present itself at idle with the clutch engaged and at low RPMs while lugging the engine a little too much. Dump an extra quart in it and roll on. It won't completely cure the problem. The only thing that completely cures gear rollover is time. Over time, it will all but disappear. Mine used to be horrible, but it only comes up now if I'm lugging the heck out of it with a good load on it.
OK maybe I'm a complete retard (if you comment on that Travis I'll fly down there just to whip your butt!) but I thought gear rollover was something entirely different. The sound you get if you hold your foot on the brake and almost bring to a stop... kind of a low growl sound. That's what I thought gear rollover is. This high pitched chirpy sound I have is something entirely different.
Well gear rollover is a low pitched growling type sound from the transmission. A high pitch would be more like a bearing or something like that.. I won't call you a retard.. Heck I did a set of ball joints last weekend. Got one hub all the way finished and realized I forgot the rotor dust shield. Had to pull it all back apart. Now that's retarded. Lol
Transfer case. Attached behind the tranny on 4x4 trucks, connects to the front driveshaft. Shifts between 2WD, 4HI and 4LO. If you have manual hubs, you can shift to 4LO but leave the hubs unlocked, and the effect is a super-slow creeper gear, perfect for reversing with a trailer. You could, hypothetically, put a transfer case behind the tranny on a 2WD truck just for the low range option. But the tranny on the 4x4 trucks is slightly different, with a tail housing that mates to the t-case.
#28
#29
CaptainFacePunch
22
03-22-2015 10:21 PM
fordzilla01
20
11-01-2009 11:00 AM
RawPower
02-24-2005 07:28 PM
