Need help.. 05 F250' idles then black smoke.
2005 F250
123'xxx miles
EGR delete kit
This is my problem, the truck Idles then revs by itself and throws black smoke.If i leave it on it eventually seems like it floods and shuts off,when i first noticed this it had a loss of power and was having a hard time shifting gears, it would idle fine but when i would try and drive the truck it had no power. I changed the diesel filters and the air filter and the problem persits.
Could this be a bad turbo? Injector?
Here is the video of the problem..
F250 problem. - YouTube
123'xxx miles
EGR delete kit
Come on over to the 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Here are some things to start looking at.
What was the battery voltage?
Have you checked the FICM?
You will get a lot of help for the 6,o over in the correct forum.
See you there.
Sean
See you there.
Sean
dwood3311
11-18-2011 10:36 AM
