Need help.. 05 F250' idles then black smoke.
2005 F250
123'xxx miles EGR delete kit This is my problem, the truck Idles then revs by itself and throws black smoke.If i leave it on it eventually seems like it floods and shuts off,when i first noticed this it had a loss of power and was having a hard time shifting gears, it would idle fine but when i would try and drive the truck it had no power. I changed the diesel filters and the air filter and the problem persits. Could this be a bad turbo? Injector? Here is the video of the problem.. F250 problem. - YouTube |
Come on over to the 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Here are some things to start looking at. What was the battery voltage? Have you checked the FICM? You will get a lot of help for the 6,o over in the correct forum. See you there. Sean :-drink |
Thanks just posted this over there.... Batteries are 2 months old with full charge..11.7 volts. I have not yet checked the FICM
11.7 OUCH!
Charging system I would be willing to bet. FICM does not do well with low voltage. See you on the other side. Sean :-drink |
