Hopefully you bought the complete harness. Then you need to hook up tps, speed sensor, and brake pedal plus plug into the tranny with the harness then you have to tie into your truck harness for the neutral safety switch ect to get the truck to start.
Yup I bought whole harness. The speed sensor? R u talking about the ones on tranny that the harness plugs into?
If so I got all that done just not the wires under dash the digital analog stuff an speedometer does all that need to be hooked up
