300 i6 blowing oil out of the PCV, oil cap and oil dipstick.
I have a 1975 Ford f350 300 i6. My problem is that there is an excessive amount of blow-by coming out of the hole where the PCV sits, the oil cap and oil dipstick. When the engine is running and I take off the oil cap, the thing smokes like a train and almost dies from loss of compression. When that happened, I put my hand over the hole to keep it running and I could feel I good amount of suction. I'm at a standstill on whats wrong with it, I can't figure it out at all. Any help would be appreciated, I will post more info if needed.
Thanks, Tom
Thanks, Tom
I doubt it. I looked at their site, no mention of services like that.
Is your engine overfilled?
If you have so much pressure that it is blowing oil everywhere, it's time for a teardown. You may have worn out rings, which really shouldn't blow oil everywhere, or a hole in a piston.
Is the oil contaminated?
Has there been a change in the way your PCV is hooked up?
I don't think the engine is contaminated because I have to replace the oil all the time from how much it burns.
As for the PCV, I just disconnected that because the compression got so high that it would just blow it out. Then, when it was in, it would push the dipstick out and cause a very bad oil leak.
I don't know if it has much to do with it, but not all of the vacuum lines are hooked up either.
Paid 4 and Love it
04-13-2012 07:22 AM
