Rear sway bar question
I've been wanting to put a rear sway bar on my truck since I bought it back in 2005. I haul a pickup camper and have SRW just as shown in the picture in my signature.
My question is... What year truck sway bar will fit my 2001? I spotted a 2004 dually sway bar at a wrecking yard and wondered if it would fit. The price quoted was very reasonable... I just would like to narrow down what will and won't fit.
Thanks in advance.
Thanks in advance.
Received 3,767 Likes
on
I was hoping to get a reference to a Ford part number that verified that across several years that the rear sway bar would or wouldn't fit.
I checked Helwig's part and it appears the same model works for '99 to at least '06... That's where I stopped checking.
Here is one way to get one:
Here is what I did:
For those of you who do not have a factory rear swaybar and want to install one I finally managed to track down all the necessary part #'s needed to add a 30mm rear swaybar.
F81Z5A772AA 30mm Rear Stabilizer Bar $99.21
E5TZ5486B Stabilizer Bar Bracket (2) $21.76 for 2
1C3Z5705AA U-bolt (2) $33.82 for 2
3C7Z5K484EA Endlink (2) $55.88 for 2
E5TZ5B498AA Stabilizer Bar Mount Bracket (2) $12.56 for 2
The washers in the pic I ended up not needing.
I purchased these parts from tousleyfordparts.com
All metal flanged center-locknuts you can source locally.
M10X1.5 (4) for the u-bolts
M12x1.75 (4) for the endlinks.
Stopped by the local pull a part today. I found a rear sway off a super duty with all the brackets. Someone had already pulled the axle so the only thing holding the sway bar on was the two upper link bolts. They even put the nuts back on the brackets!! Took me longer to walk out on the yard than it did to remove the sway bar. The best part.......$15 for the complete package!! Cha-Cing!!
Perfect bolt on fit. I had to remove the skid or whatever it is on passenger side shock mount and trim it. That took longer than the whole install. The links may be a bit long. I'll likely pop them back off and shorten them.
$15 and 30 minutes I have what Ford should have done at the factory
I wanted to update this thread now that I finally got a used rear sway bar assembly.
I paid $40 for the entire assembly at a pick-n-pull yard. It took about an hour to remove it from the wrecked truck. After cleaning it up with brake clean and lacquer thinner it didn't even have any rust to deal with.
The installation took about 2 hours, maybe a little more. The top of the end link on the drivers side was a bugger. There is about 1' between the fuel tank and the frame. I couldn't get my "sausage fingers" in there while holding the washer or bolt. I had my son help with that part. The rest of the install went fine.
Like was said before I don't know or understand why Ford didn't put these things on all of their trucks. Just driving around without a load I can feel a difference in how the truck handles. It really tightened up the back end. I can't wait until I put the pickup camper on and haul it around to really see how it feels.
I wanted to give a special thanks to Springer Pop for taking time to take some photos of which hole in the frame the end links bolt to. Thanks Pop! And thanks for the replies and photos from everyone at FTE.
The first day that I drove the truck without a load I could tell a difference in how the rear of the truck handled.
Yesterday I put about 100 miles of driving in with the Pickup Camper on the truck. Driving the interstate, in heavy rain, quite a bit of wind (20-40 mph) and cruising at speed it handled like a dream. I'm so glad that I installed the rear sway bar.
Below are two pictures that SpringerPop took of the end links and where they attach to the frame. In my haste in removing them from the wrecked truck I didn't take note of which bolt hole they went in.
Driver's side.
Passenger's side.
Driver's side.
Passenger's side.
KTM Mike
02-23-2007 03:12 PM
