I'm curious to see what people have done for seat swaps in the 80s and 90s trucks. I'm rebuilding an 84 stepside and and looking for ideas. I can get my hands on some good rebuildable bench seats, but I'd like something a little more comfortable. Let me know what you've done.
The extended cab trucks and Bronco share a similar floor plan layout where the seats bolt down. The single cab and crew cab trucks share a style. The two different floor plans are not bolt in jobs. If you're going to go through the work to adapt a Bronco seat to your single cab truck, you might as well look at any seat out of any other vehicle as both will need modifications to fit.
I swapped 86 F250 extended cab seats into our 89 F250 regular cab. I don't have pics except in my build thread. I have a whole write up in there about it. I had to use a conversion van bottom. I will also tell you that I will never do it again. The first link in my sig is my build thread.
Trav
Hs anyone had any luck with newersuperduty seats? I tried swapping some around from cab to cab in a junk yard. Looks like you should still have room but I'd like to see one already done.
