New GEM where are the turning signal flashers on this F250LD?
Replaced the GEM with the exact same number and nothing has changed except that the airbag light is now on. Sounds like a trip to the local dealer like Bluegrass 7 said in a different post. Hopefully that will take care of the problem.
I also still do not have turning signals either. I have the F 250LD and I was wondering if the flash was controlled by a relay or flasher. I checked the manual and I have power to the fuse box. Could this be a GEM problem as well?
The GEM does not control the turn signals. The flasher looks like a large relay and it is under the dash on the driver's side. Most often the connector at the multifunction switch breaks and the light blue power wire pulls out of the connector. Try moving the tilt steering wheel up and down with the turn signals on to verify the wire is loose.
