6.2L V8 Discuss the 6.2L V8
2011 F250 6.2L No Start No Crank
Old 04-03-2020, 12:33 PM
Dalton Prose's Avatar
Dalton Prose
Dalton Prose is offline
We have a 2011 F250 6.2L, 4x4 that will not crank or start.
The gear indicator on the instrument cluster will flash back and fourth on Park and M.
We have checked all the fuses, battery, starter, checked the connector on the parking brake, changed internal harness on the transmission, changed the park neutral safety switch, checked the connectors on the ECM, checked the wires on the floor by each door, checked the grounds, checked power, replaced ECM/PCM with no change.
If we jump the starter it will run.
The codes it currently displays are:
P0122
P0135
P0155
P0480
P1124
P1288
P1397
CP16A-00
P1636
P1711
P2135
P0706
P161AC
P160A
P1921
B1175-01
C1000-11
B132B-15
B1313-15
P1D03-15
Old 03-28-2021, 03:45 PM
Christian mmxiv's Avatar
Christian mmxiv
Christian mmxiv is offline
Same here
Please tell me what you did to fix this.
Same truck you have, no start, no crank.
QUOTE=Dalton Prose;19206899]We have a 2011 F250 6.2L, 4x4 that will not crank or start.
P0122
P0135
P0155
P0480
P1124
P1288
P1397
CP16A-00
P1636
P1711
P2135
P0706
P161AC
P160A
P1921
B1175-01
C1000-11
B132B-15
B1313-15
P1D03-15[/QUOTE]
retired ironworker
10-15-2019 05:09 PM
Chris Luszczynski
1999 to 2016 Super Duty
05-30-2019 11:28 AM
ranchmule
11-30-2017 06:18 AM
eaglesface123
05-02-2016 11:25 AM
GT V10
11-06-2009 01:09 PM
Quick Reply: 2011 F250 6.2L No Start No Crank
