1953 f250 wont crank
I recently got a 1953 f250 it started and ran when I pulled it of the trailer I pulled the batter and the next day I put the battery back in but hooked it up wrong it started and ran for about 30 seconds and died and now won't it won't crank I hit the starter button and the solenoid will click but it won't crank I charged the battery and still nothing and it is a 6 volt system any help is appreciated
Probably need to check your connections to the starter? I am almost surprised it started but I think series wound motors will always turn the same way no matter how you power them. Is the battery also 6 volts? post up some pictures of your truck and your location if you get a chance.
Trailered it home to Ohio from Iowa
1. Take the cable to the starter off the starter solenoid
2. Using a set of jumper cables, connect battery negative to the starter lead.
If the motor cranks over, your starter solenoid need replacing.
If it doesn't and you are sure your battery is fully charged, then its your starter.
NOTE: Using the jumper cables put the cable on your battery negative first, and then touch the jumper cable to the starter lead, not the other way around. All though rare sparks at the battery can ignite free hydrogen and make the batter go boom. (It also stops you from marking up your battery posts with the power arcing)
As an alternative, you can use a 12v battery, connect positive to same ground as your 6v battery, and connect the 12v battery negative to the starter cable, and it will allow you to crank over your motor faster to try and start it.
NOTE: Only connect the 12V negative battery power to your starter cable, DO NOT connect it to the rest of your trucks 6V electrical system. Or you will smoke things like your delicate 6V gauges.
Regards,
Kirk
Regards,
Kirk
Hi Abe,
You can see my into thread here:
https://www.ford-trucks.com/forums/1...50-f47-f1.html
Regards,
Kirk
Regards,
Kirk
1983f250guy
12-11-2015 05:22 PM
Jakedog1996
07-23-2014 05:59 PM
KANEF250
07-15-2001 01:58 PM
