1997 F350 front fuel tank inoperative
Old 08-17-2013, 01:39 AM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
This is the newest automobile I own, so I'm not knowledgeable in this area.
Recently the front fuel tank will not supply the engine with fuel. The rear tank is operational. However, I prefer to use the front tank because it's safer than the rear. The fuel gauge while on front registers fuel. Just to make sure, I put in five gallons of fuel in the front tank. It still will not supply fuel.
How can I diagnose this problem, whether it's mechanical or electrical? The only thing I can think that is, are the fuel tanks fitted with an individual pump inside both tanks, or something else as one works, the other doesn't.
Old 08-17-2013, 07:20 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Is the truck a gas or diesel engine model?
Old 08-17-2013, 01:25 PM
Island'r's Avatar
Island'r
Island'r is offline
Can you hear the front pump when you turn the key to ON without starting the truck?
Old 08-20-2013, 03:07 AM
Jermafenser
It is a gasoline truck. It has the 5.8L.
Would it be loud enough? I'm nearly deaf, so that may be not possible to just hear it. I'd have to confirm with a multimeter.
Old 08-20-2013, 07:40 AM
rla2005's Avatar
rla2005
rla2005 is offline
Each tank has it's own high pressure fuel pump inside. There is a common power path from the fuse, fuel pump relay, through the inertia switch then onto the fuel tank selector switch on the dash.
For reference (very similar to your truck):
courtesy of oldfuelinjection.com
Mikey bist
12-16-2015 03:37 PM
TheCoach
03-19-2015 08:00 PM
Passin Thru
01-26-2010 01:02 PM
connie lawley
1999 to 2016 Super Duty
01-11-2008 08:23 PM
Quick Reply: 1997 F350 front fuel tank inoperative
