friend at work has 93 f150 that will take awhile to start. starts right up on starting fluid. fuel pump keeps running. it has about 58 psi of pressure and only leaks about 5 psi in a 5 min. whats next step reg,relay?
You can check the fuel pressure regulator for signs of leaking by removing the vacuum line then check for signs of fuel leaking out of the FPR by sight and smell. The 58 PSI reading you got (KOEO) is correct for a 4.9L engine.
