Small block Ford motor mount question..
I bought a front end kit to convert my truck to Mustang II IFS type suspension..It came with the weld in mounts for Ford SB.. What year and model mount that bolts to the block did you use? The ones on my mustnag have a single stud that goes thru the K member..THESE look like they require a horizontal bolt running front to rear. What do I need to get? Thanks for any help you can offer.
I just installed Heidt's motor stands (MM-130) on my Must II. It uses the thru bolt type motor mounts from a 1966-1969 v8 mustang.
Like these
http://item.mobileweb.ebay.com/viewi...d=161035144947
Like these
Those are the same one's I got. Oreilly's and Napa carry them for $10 each.
Anchor 2257 - Engine Mount | O'Reilly Auto Parts
If the ear type mounts fit; look into the adjustable mounts. I installed them on my 67 mustang with a 302 a few years ago and love them! I kept tearing the rubber on the standard motor mounts (only one side ) so wanted to go solid and found these. I also have a 700R4 trans, so the adjustable mounts made that quite a bit easier to adjust, etc. You can buy them adjustable up/down and fw/back.
6110 Mustang Ron Morris Adjustable Motor Mounts Stock Height Small Block 1964-1970 | CJ Pony Parts
I remember paying less than 100 for them... but it was a few years ago, aparently they have gone up!
Stan Balafas
36
02-22-2017 03:53 PM
Holehawgg
17
07-08-2012 07:41 AM
77-150shortbed
09-17-2007 07:20 PM
sancochojoe
06-30-2005 10:16 PM
svooom
08-20-2004 12:25 PM
