Problems with 4R70W Auto Transmission
Hello,
I have a 1997 Ford Thunderbird V8 with the standard 4-speed 4R70W automatic transmission. I just bought the car and it has a total of 51,800 miles on it. The day after I bought it I had the ATF filter and fluid changed. Big O Tires used Valvoline Maxlife ATF. My previous car was also a '97 TBird; they used the same ATF and it worked out fine.
The ATF fluid has the correct level, color, and smell. On a level surface when I am going 40 MPH and I release the accelerator, the car slows by a bit too much, almost as though the brakes are slightly being applied. When I am coasting or at a full stop and I press the accelerator, there is a slight, split second pause, then the car accelerates. When I am stopped and in Drive, the engine runs slightly rough and the transmission makes a slight turning noise. In Park, the engine runs smoothly.
My previous '97 TBird did not do this. Can someone tell me what the problem is? Is it a solenoid or a vacuum sensor?
blueeyedfordguy
General Automotive Discussion
26
05-10-2011 07:35 AM
azfordf100man
09-14-2007 06:43 PM
