lets see some 'homemade' fixes!
Don't have any pictures but back in 1985, when I bought the Pumpkin the exhaust was shot. The muffler was rotted out pretty bad.
At the time I didn't have the money for a new exhaust (I wanted duals) so I took some Mountain Dew cans and cut the top and bottom off, then slit the side so I ended up with a flat piece of metal. I took them, I forget how many, and wrapped them around the muffler. Then I took tie wire and secured everything.
I probably drove it six months like that before I had the money saved up for the exhaust.
That same system (the duals) was still on it when I retired her 11 years later and, in fact, that same exhaust is still sitting in my backyard.
on
1 Post
No pics either, '77 F150 4×4, driving home from work after picking my daughter from daycare. Prob ten months old asleep in the car seat. Turned corner and the last bolt fell outta the rag joint. Put her in the ditch. No bolts , but had a 302 laying in the bed. Stole two bolts from the intake...cool.... crap no nuts.
hmmm. Smoke cig and think a bit. Ah ha, body clips behind the city horns. Drove her home and never did put those horns back on the rad support.
I've done my share of shadetree repairs to get home or get it running but I don't leave hacks in place. My last one was breaking the shift linkage on my PT coming out of the toll gates on the Oakland-SF Bay Bridge on my way to a SF Giants game. My repair was to strip a length of power cord for its copper wire to secure the cable's eye to the tranny's shift lever. I shifted gingerly all the way to the ballpark and we only missed two pitches after getting our beers and Sheboygan brats.
I get very leery when I see that kind of stuff in a vehicle I am interested in because that tells me there might be other questionable 'repairs' hidden elsewhere. It's all good if it's your rig but watch buyers run for the hills if and when it is time to sell.
This is under my dually
on
1 Post
on
1 Post
The ultimate classic. My brother developed a pin hole in his heater hose on his chebby. Side of the road and cold. We had a lawn shears in the truck, so he had an idea. On the count of three, he was going to pull the hose off, I cut four inches off (pin hole and all) and he slams in back on with minimal coolant loss. 1,2,3,snip,blang. Success.... but I cut the pointer finger tip off his glove. "Whoa, that was close"
I am doing an extensive rejuvenation on a 94 f-250 2WD 5.0 work truck I am now in the process of painting the frame that has become unusually rusty considering it is an Arizona truck. I came across two ground straps that went frame to grill and frame to cab. I decided to yank them off as they were the "slip on clip type" and replace them with decent bolted on cables
I'm glad I did that after seeing the corrosion that got under the rivets when I drilled them out. I wanted to secure the ugly frayed insulation on the EGR valve tube with the braided cable piece. 3 wraps and a screw, nut , and trim voila!
Then I took the clips they polished up nicely on the wire wheel (Stainless Steel) And with a little bending sand trimming fixed the MOST ANNOYING Broken part common with these trucks.
Here is the stock non broken (yet) one.
Here is the old ground strap clip made into a visor hanger that will not break off. I ground down the stock base and screwed it on. Worked great the first try. I am also going to add 2 more hangers to the sides to keep the visors from flopping around when used on side windows, I just hate that...
I hope someone will use this and FOMOCO hires me for an engineering position.
