08 SD diff cover and vss questions
Ok I'm getting ready to inspect the tone ring in the rear diff that the vss reads off of. What do I need to look for I just replaced the CSS with abrand new ford one. And had issues again yesterday with the shifting it pulled the vss error code again wiring is fine to vss.
I decided to upgrade diff cover while I'm at it
Help on this would be appreciated
Check for any chipped teeth in the tone ring. Also make sure its clean. You'll see it and understand when you get in there. As far as a diff cover, I bought one from riffraff, spendy. There are a LOT of aftermarket covers, pick what you like and buy it. If you happen to buy one that has an oring seal, don't just trust the oring to seal. Ask me how I know...
nddragon01
2004 - 2008 F150
12-25-2016 02:30 AM
motor-man
1999 to 2016 Super Duty
17
02-15-2010 12:04 AM
