water pump and thermostat ?
08-03-2013, 06:38 PM
on
Is there a long and a short thermostat if u put a stort
were long was what would happen
08-03-2013, 07:55 PM
Yes there is a long and short
08-04-2013, 07:59 AM
This shows a long stem thermostat in a water pump that needs a short stem thermostat.
08-04-2013, 08:22 AM
on
K what happen if u put short were a long should go as far as
temps on the eng.
08-04-2013, 08:33 AM
I'm not sure but would guess the coolant would bypass the thermostat making the thermostat ineffective.
08-04-2013, 08:56 AM
on
When u put the 6.0 fan on what different. Did it make
And I am putting the fan on my clutch is that ok
08-04-2013, 02:23 PM
They say the 6.0 fan moves more air but I haven't seen much difference. It does weigh less which isn't as hard on your water pump. You can put the 6.0 fan on your clutch.
08-04-2013, 05:49 PM
Quote:
Originally Posted by
mikec91
temps on the eng.
oldbird1965
Don't know for a fact but have read the rear cylinders will overheat.
08-04-2013, 06:34 PM
on
11-11-2013, 07:39 PM
on
Just wondering, do you have to remove the whole housing to get the thermostat out? Or is it simpler than that?
11-11-2013, 07:44 PM
Fameus
You just remove the water outlet from the pump housing and you can take the thermostat out.
11-12-2013, 07:18 PM
mikec91
temps on the eng.
This was the problem I found when I bought my truck. It would never warm up as the short thermostat couldn't reach it's sealing surface. Replaced with the correct lenght and it warms up a lot quicker now.
11-12-2013, 07:31 PM
LeoJr
Here is a picture of the opposite situation, LOL
Totally Tuna
03-27-2018 11:44 AM
Royson12
16
05-31-2014 07:19 AM
diehardstroker
15
04-06-2014 02:50 PM
jbrown9709
07-17-2012 05:42 AM
firebug
02-01-2006 06:36 PM
